how to add puddle lights
1 Attachment(s)
adding the puddle /entry lights easy but takes some time since you have to remove all 4 door panels
see the indent in bottom of panels Attachment 36683 __________________ |
1 Attachment(s)
1 Attachment(s)
cut out with dremel, don't go nuts you can always make the hole bigger
Attachment 36681 __________________ |
1 Attachment(s)
1 Attachment(s)
1 Attachment(s)
installed and working actually put out a surprising amount of light at night
Attachment 36678 __________________ |
in addition to these there is supposed to be a light in each upper kick panel under the dash, they are the same lens and bulb as the puddle lights, drop the upper kick panels the hole is already cut just install the lens with bulb then locate the plug and plug in, stupid easy, can,t believe they were not just there from the factory
| All times are GMT -5. The time now is 07:14 AM. |
