how to instal console fridge
1 Attachment(s)
fridge install
ok this is easy to do block wheels put shifter in neutral, pull up and twist on shifter handle it pops off there is a screw in front of the park brake lever, it can be Phillips or torx, remove it flip open console lid, remove the rubber mat under the ashtray area now grab and pull up the top of the console on the sides where the top and bottom halves meet it is hard to remove but will come off you can now lift it high enough to get past the shifter stalk and rotate it clockwise 90* , the wiring is tight so be careful, I unplugged it all to get the cover off all the way there are 3 plugs; park brake, shift lights, off road selector ( this one was hard to remove had to use a screwdriver to ease it out) now there are 2 screws in the front one on each side at front of the glove box ( see pic) next put both front seats forward, take a torx remove both console lid hinge bolts, and the hinge caps ( see pic) now grab the cubby box and pull up hard it has clips on bottom last locate the fridge plug, it will have a piece of foam wrapped around it, drop in the fridge and reverse procedure Attachment 36689 __________________ |
1 Attachment(s)
pic remove screws and caps for lid hinges, that hole in the fridge flange is for the factory satellite radio
Attachment 36688 __________________ |
1 Attachment(s)
1 Attachment(s)
empty console
see the grey foam near the driver seat belt that the plug just ditch the foam and untape it from the harness to get slack Attachment 36686 __________________ |
1 Attachment(s)
now if you want to remove the rear panel on the console this is the time to do it since the cubby hides this screw, unscrew it and pull straight back on the rear panel it will come off
the plugs are under there for the rear heated seat buttons they are green but covered in foam Attachment 36685 |
1 Attachment(s)
installed with the coin tray installed and turned on, it takes a second or so for the switch to light up, I also think it only works with engine running gets real cold real fast few minutes maybe
Attachment 36684 __________________ |
| All times are GMT -5. The time now is 01:23 AM. |
