how to repair remote not working
tips on why the remote is inop
I took it apart hoping the battery was unsoldered like the remote for our 06, no such luck
I checked it with a meter battery is charged the remote
note: the remote is not made to come apart and will need to be crazy glued back together, I used gorilla brand seems to work well
it is actually a little difficult to pry open for obvious reasons, just be careful not to lose the springs and button for the key, remove your extra keys it will make reassembly easier
if your remotes do not work and water has gotten in from clogged drains etc., pull the passenger front plastic door sill up it is held with metal clips, it will reveal this harness.
look for 3 thin wires green with white stripe, found the 3 wires and stripped them back to clean wire, added an extension wire soldered and shrink tube now the remote works
Here is a pic of the wires
The other issue with remotes
The lithium battery in the remote is perminant and soldered in, it charges through the ignition switch, its around 3volt battery, the battery comes unsoldered
The remote is sealed and not meant to be opened
I have fixed 1, open the key and get in the slot with something to pry the halves apart it takes a lot of effort
When it opens do not lose pieces of the key, there is key,spring,button and metal piece for keyring
Use a multi meter to test battery around 3v iirc
Fix the solder joints
Try remote, it should work now
Reassemble and super glue the case together( you can also try a cheap new eBay case) you will need to wind the key spring some sorry for no pics
tsuyoi
09-22-2020 10:37 AM
saadekhoury
12-11-2011 11:08 AM
