Thank you LR!
My understanding is that the RRS and LR3 have the same brakes, with the exception of the front Rotors, which are larger to accommodate the Brembo Caliper. The rears are the same, AFAIK... |
Originally Posted by Daniel-LR3
(Post 677410)
Thank you LR!
Originally Posted by loanrangie
(Post 677411)
Yes, so the calipers are spaced out further hence the need for the V8 carriers.
I am sorry but I do not understand the reference to the "V8 carriers" unless you are talking about the knuckles. So just to be clear, the Brembo RRS caliper will bolt up to the LR3 HSE knuckle without any modification using the RRS rotor which fits over the LR3 HSE hub. Is this correct? Will the Brembos fit under the standard 19" LR3 HSE wheels? Thanks in advance. |
Range Rover brakes on LR3
(Post 677410)
Thank you LR!
I'd also like to hear more about this, as the LR3 brakes aren't particular great in stock form. I haven't researched it myself, but it does make sense to me that the SC caliper brackets would also be needed, as mentioned above...
Brakes
Originally Posted by tracyc
(Post 877421)
Originally Posted by Bullpup
(Post 750833)
I am sorry but I do not understand the reference to the "V8 carriers" unless you are talking about the knuckles. So just to be clear, the Brembo RRS caliper will bolt up to the LR3 HSE knuckle without any modification using the RRS rotor which fits over the LR3 HSE hub. Is this correct?.
I am going to clarify the above a little here. The calipers are identical in size, the only differences are the caliper brake and rotors. So if you have the smaller brackets and smaller rotors, you need to swap those, not entire calipers. But as said, in NA markets, I too believe only one size of rotors and caliper brackets are used being there was only the V6 and V8 petrol engines and probably why there were no 17" wheels to be found in the NA market also.
Brembo Brakes
https://cimg3.ibsrv.net/gimg/landrov...d4e3228ac.jpeg
Here is an example of brembo brakes. I just looked up Range Rover brembo brakes so these are probably not the model that fit the LR3. Brembo brakes do away with caliper brackets or caliper carriers. Just a massive thing that straddles the disk and bolts on where the bracket/carriers do. |
Originally Posted by Miguel987
(Post 877458)
