LR3 Incorrect Immobilizer Key code
Old Nov 18, 2022 | 10:07 PM
DakotaTravler's Avatar
Default LR3 Incorrect Immobilizer Key code
P0513-00 (28) Incorrect Immobilizer Key
This code has been coming up for a long time with either key. I actually think it started when I programmed a second key with the GAP tool. I don't ever seem to have starting issues. I know there are more than a few ghost codes that come up on these trucks often, but this one worries me simply because of the places I go which are often remote and hundred of miles from anther human. So any ideas?
Old Nov 19, 2022 | 09:24 AM
SeattleDriver's Avatar
I think you are right to be investigating before it potentially becomes an issue.
This seems be a very uncommon code. Not many references to it on the forums, GAP manual, or LR3 shop manual. I suppose JLR may be silent on immobilizer design for security reasons.
One of the few threads I found on the topic suggested it was relieved with the proverbial new battery. Given yours appeared after programming a new key, I’d start there. Do you happen to know which key is the “new” one? Try clearing the code and then exclusively use the “old” key for a while to see if the code does not return. This won’t fix anything, but it could help pin point the problem to the key or the immobilizer.
For an actual fix, I would try removing the new key from the memory and then reprogramming. Its possible something minor in the programming didn’t take.
Here’s a thread I found:
https://landroverforums.com/forum/lr...houston-86154/
Old Nov 20, 2022 | 09:53 AM
But it come up wither either key after clearing. I could try a reprogram, but I am a touch paranoid about bricking the truck. Battery is new, only maybe 4 months old plus I have an aux battery setup. So lots of juice to get her going with standby voltage about 12.6.
Old Sep 3, 2024 | 05:07 PM
For the record, this still comes up time to time without a valid reason. Seems to always start. Did reprogram keys, no difference.
Whiteboard55
Jun 1, 2022 07:23 PM
mr. choodles
Feb 6, 2021 04:48 PM
Geo
Feb 6, 2019 12:35 PM
Lynton
Nov 9, 2013 05:40 AM
aarongregor
Jan 21, 2013 11:39 PM
