-   LR3 (https://landroverforums.com/forum/lr3-28/)
-   -   Lr3 instrument cluster issues (https://landroverforums.com/forum/lr3-28/lr3-instrument-cluster-issues-76878/)
Smhube00 Dec 11, 2015 03:37 PM
Hi all
I have 2009 lr3 hse
Have 80k miles
Last week equipment cluster start acting up
Start getting alarms such as HDC is not available , parking beak errors , tire pressure monitoring system not working ect
It will drive fine until I stop and turn the engine off. It will not start for while.
I took it to the dealer. They are telling me that I have bad instrument cluster
It is going to cost me $1500 to replace it.
Does anybody had similar issues ?
Is there way to fix what is broken on the equipment cluster vs replace the whole thing
Any advise will be appreciated.
Thanks in advance
houm_wa Dec 11, 2015 04:51 PM
Check the battery first!!!
Smhube00 Dec 11, 2015 05:05 PM
Checked the battery. It is good
TOM R Dec 11, 2015 05:19 PM
Is the passenger Floor wet underneigth the padding
KMET Dec 11, 2015 05:32 PM
Have not heard of cluster failures... Could it be that brake light switch above pedals?
Smhube00 Dec 11, 2015 05:40 PM
Passenger floor is not wet
I change the break light switch just in case, no change
KMET Dec 11, 2015 05:52 PM
Have you tried cycling through gears before trying to start it?
I see you had the CATS replaced recently... Anyone know what parts are removed to change CATS?
Smhube00 Dec 11, 2015 06:31 PM
I will try cycling the gears when I get home
Dealer did the cat change under 80k warranty
abran Dec 11, 2015 08:25 PM
I have a customer that has the same problem.
They bought the cluster from the dealer for $1400, and are having me do the software download and resync.
If it is your cluster, $1500 installed is not that bad.
Smhube00 Dec 14, 2015 06:21 AM
Have you already done this work ? Just wondering whether that fix the problem?
Dealer is telling me that the material cost is $947.
