LR3 remote/key issue
I've had constant issues with my remotes/keys for my LR3 since pretty much the day I got it.
It has been back and forth between the vehicle not responding to the remotes, and then at other times the vehicle responds but one of the keys stops working. I'm fairly certain it has been a combination of a bad receiver, and one bad key.
After over a year of asking, the dealership finally warranty replaced one of the keys. Everything worked fine for 1 month, then both remotes started not working intermittently again and now both work 1 out of 20 times at best.
I'm out of warranty now and assume they won't cover repair of the receiver. Is there anything I can check myself that might be causing the issue (i.e. a loose wire or something)??
When I'm out to the truck solo, it's no problem. When I'm trying to load 2 kids in or lots of fishing gear, it stinks.
Is the wire one I could replace easily enough if I find it to be corroded?
Thanks so much for your reply. I'll go hunting for the wire, hopefully today.
It's easy to reconnect the wire; what's difficult is actually accessing the wire. I ended up removing the front passenger seat first, which makes it easier to then remove the sill piece. Undo the black tape on the loom and look for a green/white wire a couple of inches in front of where the seat would be. If I recall correctly, you'll see a section of the wire wrapped with blue tape. That's where the corroded section is. Mine was so corroded that giving it a gentle tug caused the wire to break apart. Putting the sill back on was a MAJOR pain because the metal clips kept falling into the holes.
77_scorp
07-15-2018 08:26 PM
bcolins
12-08-2013 09:17 PM
RROJ
10-09-2010 07:39 AM
RROJ
10-08-2010 09:56 PM
