Mass Air flow Sensor question
Hi .My Repair Shoppe refuses to clean my Mass Air Flow Sensor..they say too delicate and good chance of damage on an expensive part.
Have they got it wrong. It just seems to be a bit of MAS Cleaner by CNC sprayed on it. When AC is on car wants to stall. Thank you |
You can spray them just fine, just do not touch the wires. Cleaner specific for MAF will work or non-residue electric parts cleaner is the same. Also visually inspect the sensor after cleaning. The wires should be clean and metallic looking. If there is corrosion, yellowing or darkening them its probably time to replace it. The OEM sensor is Denso, so you can buy a Denso/Toyota part for less. 22204-22010 But there are cheap Denso MAFs for $20 which can be hit or miss. Going over a year and a half on my cheap one and so far so good. But a genuine Denso, probably $75 up. Still much cheaper than a Rover "genuine".
(Post 693759)
If I need one where would you go to buy one? If car is having the shakes with AC on is it likely it is that do you think? Thank you so much for the advice on MAF sensor.. : ) |
You can buy them from the dealer or online.
No clue, but if the shop says its the MAF then maybe it is. But I would expect a check engine light and code. |
Rough idle usually leads me to cleaning the throttle body as well.
Jeff |
(Post 693819)
Originally Posted by Rufflyer
(Post 693832)
Jeff |
You can push open the door with ignition off.
door = throttle plate, fyi :)
[QUOTE=DakotaTravler;693940]door = throttle plate, fyi :)[/QU
Thank you I didn't know.great. |
