-   LR3 (https://landroverforums.com/forum/lr3-28/)
-   -   My LR3 plays a new tune now... (https://landroverforums.com/forum/lr3-28/my-lr3-plays-new-tune-now-97475/)
Philip Chan Nov 10, 2019 05:46 PM
Well then...I can't figure out this one.
The other day I pulled away from a parking spot and the thing rattled. Like, noticeable rattling - backing up, going forward, turning left and right. It eventually abated, but caused me alarm.
It honestly sounded like a dull tin can being dragged crossed with a grinding (?). I couldn't replicate it driving, but noticed It happens when starting from cold/parked. No codes from GAP.
At first I thought I came from the engine bay, or perhaps lower. I've replaced the control arms etc.
Question: What does the front diff sound like when it is on its way out? Is a constant noise? Could it be this? Thoughts?
DakotaTravler Nov 10, 2019 05:53 PM
So the sound was only when in motion? Could be a wheel bearing going out. I had the oddest sound when mine went and thought it was ice impacted around the control arms or such. Was during an exceptionally cold period. And when driving the sound would go away. You can rule out bearings easily enough when trying to move the wheel around by hand.
Philip Chan Nov 10, 2019 06:15 PM
Good question.
I was sure it made the noise prior to moving - hence I thought it was something in the engine bay. I will try and take note next time I start out.
It was alarming though - almost to the point I thought something was about to fall off.
DakotaTravler Nov 10, 2019 06:16 PM
Could easily be belt related. Pop the hood before your next start so you can hop out and get a better idea.
Globetrotter448 Nov 10, 2019 06:24 PM
Could be timing chains on start up especially if adjuster is RS. Check you do not have a crack at the oil pump where the belt tensioner mounts
ArmyRover Nov 10, 2019 07:42 PM
Or an exhaust shield
Philip Chan Nov 10, 2019 10:22 PM
I managed to grab some video here:
https://drive.google.com/open?id=1xM...ZAddGSG6J-tofY
DakotaTravler Nov 10, 2019 10:23 PM
Yeah... I am not clicking that.
Philip Chan Nov 10, 2019 10:39 PM
Ok ? Not sure why?
here on YouTube.
DakotaTravler Nov 10, 2019 10:41 PM
Certainly seems engine related and given the clarity maybe something external. Water pump, tensioner, etc. Pull the belts and check out the components you can spin by hand.
