P0171; stalls; replaced throttle body
The PCV on these hisses, even when new or when otherwise working properly. It’s a common mistake to assume it’s failed when you hear it hissing.
The crude way to test a PCV system is known as the “glove test.” You remove the oil fill cap and, with the engine running, place a surgical glove over the opening. The glove should lightly pull into the oil fill tube. If the glove inflates, the PCV system has failed somewhere —clogged hose or failed valve (the UFO thing). The proper way to test PCV uses a manometer to accurately measure vacuum.
The following 3 users liked this post by SeattleDriver:
I replaced the TB because I felt like I had tried all other options. Since it had no effect, I’m going to put the old one back in. Might it help to reset settings or check them anyways with the old throttle body?
The stalling happens intermittently, if that helps determine what to check or replace next. Again, once I cleaned the system the truck ran great for half a day.
Rovernewb15
05-11-2016 02:19 PM
wisconsinoverlander
11-16-2012 12:25 AM
