Fmb Choppers Fmb Choppers |
05-26-2015 12:31 AM |
Pressure washing LR3 engine not a good idea
So after spending last weekend replacing brake pads, brake rotor, lower control arm bushings, sway arm bushings and Tie rods, on my 2006 lr3 with over a 136K of miles on it, I thought I would wrap up the remaining items this memorial weekend and replaced the front main bearings, half shafts, water pump and replace all the fluids. So I get done and the car is running smooth I have a huge smile on my face and I think lets wash the engine bay and when I get done cleaning everything and start the car up, my dash lights up like a Christmas tree with the Low range light-flashing green, DSC- solid amber, BRAKE- solid amber, With the messages: SYSTEM FAULT SPECIAL PROGRAMS NOT AVAILABLE, HDC FAULT SYSTEM NOT AVAILABLE, SPECIAL PROGRAMS OFF and the range selector in the center is flashing, and when I put the car in drive or reverse it will not engage basically the transfer case is stuck in neutral. I about lost my S_i_!
I take the battery out, take a look at the transfer case transmission module. And the multi pin terminal blocks have a ¼ inch of standing water. I removed the module and cleaned it with contact cleaner and opened it up and cleaned it with contract cleaner put everything back together started the car up and all lights were still there, and the Drive and reverse still would not engage, I pushed the range change selection switch forward to see if I could get the module to put in high and on the 3rd try it went into gear and most of the lights went off, I drove the car a few miles turned it off and when I started it again all error and light were gone. I don’t think I will be pressure washing my engine bay again. She is one sensitive Bitch
