quirky issue with my lr3
Hey guys
ive got a 2005 LR3 se with approx 93K on it. She's by far the best thing ive ever owned. It's love, im all rover. Now I understand that owning a rover requires a certain temperment so I'm totally prepared for its level of reliability.
With that being said I've got an odd list of symptons that I'm trying to figure out.
It all stated with what I thought was a tail light bulb that burnt out. My rear passenger tail light seemed burnt out. So i ordered some OEM bulbs and installed them. It seemed as if it didn't work. Until I had my girlfriend stay in the car and work all the lights it seems that the bulb that didnt work works as a brake light just not a tail light.
My battery is new, although I did see a little funky build up on the bulb connector. Not sure.
So then driving down the road a week or so later I go some symptoms
bunch of beeps followed by
HDC Fault
Transmission Fault
Suspension Lowered
special programs off
Car squats down rides rough blah blah.
Let it have a moment to collect itself with the ignition off and all is healed.
It was fine for a few weeks until today when it did it twice.
First two times it happened was under long steady braking coming off the highway.
Other time was just after starting with my foot still on the brake i turned the lights on and then it wigged out.
What should I do?
Also something else I noticed is that when I lock my car it only seems to lock some of the doors. I have to click the lock button many times to get it all to lock up. I did have to buy a new key fob when i bought my car and never had it "programmed" Not sure if this is a symptom of an electrical issue or not
Any help would really be appreciated
Cheers,
Stan
HDC Fault
Transmission Fault
Suspension Lowered
What should I do?
Cheers,
Stan
unseenone (06-13-2015)
I would lean toward the brake light switch, it is known.
On the locks, I recently replaced the rear latch mechanism, display the same symptoms. Some people say you can remove them and repair them and reinstall. I opted for new ones, and have the old ones to tear apart and try to fix them... It wasn't bad, I designed a special tool to reinstall them.
I figured if I can fix them I would sell them as refurb for about half the price. The new ones were around 100+ a piece. The two I did were the two rear doors.
W/Central Locking Rear Doors
109.23 ea
FQM500380 Right
FQM500390 Left
Stop / Tail Bulb
XZQ000020
License Plate Lamp (keep spares)
XZQ000060
Brake Light Switch
XKB500110
109.23 ea
FQM500380 Right
FQM500390 Left
Stop / Tail Bulb
XZQ000020
XZQ000060
Brake Light Switch
XKB500110
when you say nothing, did the symptoms change? There is a short somewhere it sounds like. Have you had a water ingress problem at all. Maybe pull out the light fuses, one by one and see if the symptoms change to narrow it down to what circuit the problem is in.
The quirkiness with the brake switch is related to a common ground on all these systems.
what i meant was that after the brake switch replacement im still having the same problem namely, when and only when i turn on the lights ( to any setting) the car bongs, tells me i have a transmission error, the brake light stays on as well as the traction light, all special programs are off and the suspension lowers.
I do have a tail light that looks out but the same bulb works under braking.
I havn't noticed any water egress issues, the car smells ok where do they typically leak?
also which fuses relate to the lighting system ?
ok so just an update the issue has gone away it seems.
I cleaned my battery terminals, they were slightly corroded and ugly. I used a bit of baking soda and water with a good wire brush to clean them up. Reassembled and no luck i still had the issue.
Next i took out each tail lamp, removed the bulbs, cleaned a little gunk on the contacts inside of the bulb housing. laced profanity upon both tail lights and problem solved.
One bulb, the right rear bulb on the upper portion of the lamp assembly just looked a bit crusty i suspect that may have been the one
thanks for all the help guys, hopefully this cures it. Riding with the suspension lowered blows !
nh9095
01-14-2019 12:36 AM
tunernewb92
10-20-2009 07:15 PM
