-   LR3 (https://landroverforums.com/forum/lr3-28/)
-   -   Radio Swap (https://landroverforums.com/forum/lr3-28/radio-swap-89025/)
EastCoast 04-10-2018 09:31 AM
Radio Swap
Will a radio from a SE work in a HSE?
Thanx...
memphis_rover 04-11-2018 12:20 PM
I don't think the actual head units are different in the SE/HSE besides the addition to the screen, but the amp is different. (more speakers)
ArmyRover 04-11-2018 07:14 PM
yup shouldn't be an issue at all. I have done HSE to SE with no problems
EastCoast 04-12-2018 10:22 PM
Thanx to you both... my radio reception is crap to put it kindly so I'm looking at buying a salvaged head unit and popping it in. Just didn't want to waste my time on an incompatible unit.
Geo 04-13-2018 12:20 AM
Maybe your radio antenna amplifier is dead (fuse?)...
Found one on eBay for $10
Search for XUC000262A
EastCoast 04-15-2018 05:23 PM
Checked fuse... good.
I've got a question though... where is that antenna amplifier located?
Thanx...
Geo 04-15-2018 08:31 PM
That’s a good question. Usually they are in a pillars, but I have my covers off and don’t see them. I also have the dash apart and haven’t run across it yet. I’ll take a closer look. Might be around the central junction/body control module.
EastCoast 04-15-2018 10:38 PM
Thanx Geo... could it be under the headliner underneath where the antenna is? I hope not as I don't want to drop my headliner if I don't have to. (more of a "never done that before" than a difficulty rating)
Geo 04-16-2018 06:57 PM
I followed the antenna cable down the left side if the dash/console and then over towards the passenger side behind the shifter. Not sure where it was going!
Passenger side B pillar maybe?
EastCoast 04-16-2018 10:46 PM
I removed the rear cover at the rear of the headliner and there is nothing up there. I may try and contact one of the salvah=ge yards that has these for sale to ask where they took it from.
