Rocker switch placement???
voice phone dialing
I do not use the voice command features for the operation of the NAV or factory AM/FM; it is easier and faster to push the buttons etc.
Ah nav... I don't actually use the on-board nav anyway since it's so out of date and hard to use. I run a 10" Samsung tablet on the dash with Gaia for my off-road nav and it's just much easier to use Google maps for my on-road nav.
I see I've well and truly hijacked this thread. Sorry...FWIW I'll be looking to add some extra switches myself in the future. Right now I only have one for a rear facing flood/work light. it's mounted to the left of the steering wheel near the stock headlight switch.
left side better I figure
Somehow, the switches on the left side seems better and probably that side will be easier to use; near the key just looks to be too busy a location.
It is also probably easier to feed wire directly from the left side of the foot well than perhaps also having to go under or over the steering column.
Running wires over the column was easy iirc, had to do that for the factory off road lights
Pods look like a great idea/work in progress
Are you looking to overlay the padding on both sides of the column or replace the padding?
The one on the right looks obstructive if you had all the switches in there and additional keys hooked to the remote, IMO angle it so the side by the column is closer to the dash, I would also consider making a gauge pod option and a rocker/gauge pod option
Again love the idea
Open you can pop off the center dash /radio surround, which includes the vents and mount the rockers on the side iirc that's good and hollow in there and easy to remove
Again love the idea
