Rotating thudding sound while decelerating
OK...need some help here from the experts.
I notice a low thudding sounds while off the throttle and decelerating, usually at speeds above 25MPH. Most noticeable going down long hills. It sounds almost like a tire out of balance or a wheel bearing type sound. If I out it into neutral, the sound goes away. More info: 06, almost 100k, previous owner did all dealer service. Not tires: New tires just went on. Same before and after. Both front complete control arms were put on when I bought it. Alignment done when I bought it. It is not louder while turning. Nothing heard while cruising with throttle applied. Transmission shifts perfect. High/Low range works perfect, all diffs lock as should (was just off road last weekend going to a hunting/ski lodge...mud, snow and even pulled my friends Silvarado out of the mud). Used all programs. Has rear locker and it engaged a few times. Sound seems like it is coming from the front but hard to tell. Tried to take video/audio but it isn't audible on the recording. It is not super loud, but I hear it. Any thoughts on this? Have a few longer ski trips coming up so want to see if there might be something to address. |
Does it worsen when applying the brakes?
| All times are GMT -5. The time now is 01:31 AM. |
