How difficult was replacing that?
Literally directions in the first reply to this post.
Saw that, was just curious. Thanks.
Anyway to reset fuel adaptations? If you can and the issues is gone, then it may lean towards something like MAF/O2, etc. If you and the problem persists I would expect something like a throttle position sensor, etc. Something with absolute valves gone afoul.
App sensor
Originally Posted by AndrewGr
(Post 690731)
Thanks Savannah. After three years and investing several thousand dollars into other potential fixes - your suggestion solved the problem. No more RPM fluctuation. It's gone. Fixed! I cannot believe that replacing the gas pedal assembly (which includes a new APP sensor / gas pedal position sensor) finally solved the problem. Thank you so much!
Originally Posted by Frank key
(Post 766314)
Hi, did this also fix the small kick when coming to a stop? Thanks, Frank
Hi
When the car is making this rpm fluctuation, the motor temperature is working in the panel? |
A couple years ago, I had occasional rpm fluctuations, same as described. I thought I might have a serious problem, but it was completely fixed with a fluid/filter change and a proper refill.
Hi
On my car, make RPM fluctuation, the motor temperature didn`t mark, automatic gear box didn´t work properly . . . .and the guilty was only the temperature sensor in the gear box, broken, no connection. After I shunt the two pins, all work perfectly. |
Rpm fluctuation
Hello, experiencing the same issue with my truck. Was going to look into switching out the gas pedal sensor but I noticed my truck does not fluctuate when I’m in manual mode only in automatic. I’m assuming this would rule that fix out?
