Sirius issues
Old May 18, 2012 | 06:10 PM
greendef90's Avatar
6th Gear
Default Sirius issues
Hi just got a 06 lr3 and the Sirius sat is stuck in channel 02. Can't get it to work. Sirius says call dealer and have tried everything. Anyone solve this
Old Jun 2, 2012 | 04:45 AM
rewillia's Avatar
I'll offer this. Had a similar problem with one of my Mercedes-Benz OEM factory installed Sat radios (2008 CLS550) that would not seem to take an activation signal - ended up being that my radio would only accept the Sirrus standard subscription not the XM/Sirrus Premier sub. This after having MB change modules, check antenna, etc, etc....once I had Sirrus change to the standard subscription the radio activated...no more problems.
May not be applicable to you but you may want to ask Sirrus which subscription you have and try the alternative to see if you're vehicle will accept it.
Sounds like a "stretch" but that was the fix that solved my reception/activation problem.
KWAYZ
15
Dec 28, 2009 09:59 PM
jsdkms
Oct 29, 2007 08:52 PM
fanatic516
Jul 28, 2007 10:18 PM
harry_123
Audio/Visual Electronics
Aug 16, 2006 05:07 AM
Deutsch100
Aug 4, 2006 11:44 PM
