Google search shows leaks from
sunroof drains clogged A pillar covers Hvac drains clogged Passenger door seal Windshield not glued in correctly Hvac intake cowel shield fell off Hole in sunroof drain hose |
Tom thanks for the pictures - I do agree that it looks as if something snapped to the face of the hvac intake there.
As far as your a pillar alignment pegs being broken off - I'm pretty sure a dealer actually performed the TSB on your vehicle. They are supposed to cut off those pegs flush, and use included adhesive seals to cover the hole. When I popped mine off the seal was basically flaking away (great land rover..) but someone had already done the TSB. Also I believe there should be the TSB yellow trim snaps with foam seals on each unlike the factory ones. |
Nope pegs www there just broke off, lots of right stuff sealed it
Well rain rain rain, floor appears dry, no small pond yet so hoping it is fixed, not sure what exactly I did that fixed it or a combo of things
My water leak fix
Hey Tom mine had a water leak on the driver side and passenger side. My fix was to get a new cowl because mine was warped. I also placed a cover over the air inlet for the cabin filter which was directly below where my cowl was warped, Here's a link to what I constructed... DISCO3.CO.UK - View topic - No more water ingress/passenger side...possibly
The drivers side was a ripped elbow where the water drained from my sunroof. It is located below the hood release latch on the driver's side. |
Good to know, mine seems fixed for now
Nice! Mine was dry after all this rain as well, while I did a better job at the A pillar fix than the guy before me, I believe using some black RTV on the cowl fixed the issue actually.
The 06 is missing an a pillar cover, looks like it was rtv on previously
Pouring rain today floors dry
| All times are GMT -5. The time now is 06:21 AM. |
