thermostat removal/change?
Do you mean the entire housing with new sensor? If so, no, I just have the replacement thermostat with o-ring. I was planning on just flipping the thermostat housing upside down to work on it right there under the hood. Also is it ok to use global peak gold bottle antifreeze?
Thermostat replacement went a lot easier than i thought
It took me about 25 minutes to change my thermostat. I ended up disconnecting all three hoses and brought the housing into my house. I don't have a garage and the weather is 6 degrees, not factoring wind chill. I live in the northeast, good ole Rhode Island.
Removal was pretty easy, but you do have to push down pretty hard and than twist to release the thermostat from the housing. I used a rag to cover thermostat than twisted, and release.
When putting in the new thermostat, DON'T FORGET TO PUT BACK IN THE LITTLE THIMBLE LOOKING THING ON THE END OF YOUR OLD THERMOSTAT!!!!It lifts up with the old unit.
Other than that just reverse everything when placing back into your truck.
Bleeding was real easy. I guess on the v8 4.4, you just run your truck to normal operating temp with all vents and heat cranked. I ran the truck for about 15 minutes got out while still running and than went and unscrewed the bleed screw slowly on the reservoir bottle, and waited until coolant came out, tightened and my truck warmed right up. I have a ultraguage which shows actual engine temps, I Highly recommend getting one of these!!!
collin Barrows
08-28-2011 07:13 AM
treant985
12-27-2010 02:51 PM
