Three amigos and im stumped
Alright gents. 2006 lr3 V8 se, I have the park brake light, traction light, and roll warning light all in Amber color and the truck lowers to access mode. (Three amigos apparently) It ONLY happens after 10-15 miles on the freeway going 70+ mph. Not anywhere else. The car drives normal lowered and the abs hasn't locked up at all. I read up on it and I have already replaced the following: all brake light bulbs (all OEM), the brake light switch, and I replaced all 4 ABS wheel speed sensors (fronts were a pain) and it still does it!! I'm lost, please if any one has an idea let me know as I'm about to pull my hair out.
Thanks for the reply, by angle sensor are you referring to the ride height sensor? How would I know if one is bad? I was getting code u0121 "lost communication with abs module" battery is healthy and no issues there
It can happen at low speeds if the steering angle is way off. When i replaced my lower steering column I accidentally reattached 360° off. The truck would immediately start activating the brakes on one side when i was driving because it thought I should have been in hard turn while i was going straight. after a few seconds the code would trip and it would stop.
