Throttle/Idle issues? Clean your throttle body asap!
I was having an odd issue whenever I came to a stop, the car would idle so low the engine would shake.
Opened up the TB and while it didn't appear too dirty, I cleaned it thoroughly with http://shop.advanceautoparts.com/wcs...8_pri_larg.jpg Making sure to get the edges of the butterfly. WOW - problem gone. |
I clean mine and my MAF sensor every other oil change. Had the same problem as you did 😔. I also use BP 44K oil change as well.
I would get a reduced engine performance message rolling down a long downhill grade. Occasionally it would also stall out when I went to back into my driveway...
Cleaned the TB and never had a problem since. It's amazing just how touchy they are! I've had cars be WAY more dirty and it made no difference after cleaning it! So, I too, am a fan! Especially when it's a 20-30min job even if you don't know what you're doing! :D Dave |
Totally. I really didn't hold out much hope, especially when first looking and seeing how relatively clean it was.
Bam! - $4 and 30 minutes later and it's silky smooth. |
Tools needed? I'm having codes P0174 and P0171 show up and I was hoping this would be a first step. |
Originally Posted by babyxbuffalo
(Post 636543)
Gonna add this to my list.
TBH does freeze up and has a purpose And I know how to bleed my rover. good luck all! Hope you guys make it through the winter! its about 15 here so far. |
| All times are GMT -5. The time now is 04:57 AM. |
