Tire Pressure
Next Saturdey Im going to a rocky trail with a group and want to ask you guys what pressure do you put in your tires when going on rock. There are boulders and sharp edge rocks. Before I ve gone in trails at 25 psi, but tires still get lots of sidewall scrapes. I have General AT2 Grabbers. BTW. OEM Good Years are the worst tires iv seen in my life.
RE: Tire Pressure
what size tires are you running
RE: Tire Pressure
What size tire are you running? 18 to 20, don't go below or you may roll a bead.
RE: Tire Pressure
general at2 grabbers 255/60 R18
RE: Tire Pressure
i 20-25psi
RE: Tire Pressure
A little late perhaps to mention, but since you went through the trouble and the expense of changing out tires (agree 110% about thefactory GY's) why did you stick with the relatively low profile of the 255's if you intended to go off roading with it? I would have recommended 265 at least if you are an ocational off roader and 285 if off roading is the primary use. That way you could make much better use of diflating with the taller side wall. Also, if rock crawling is on your plate at least occationaly, then tires withbuilt inwheel protector would be high on my list of choices.
RE: Tire Pressure
ORIGINAL: gtiturbolr3 Before I ve gone in trails at 25 psi, but tires still get lots of sidewall scrapes. |
