Transmission Fault Warning
Old 07-30-2018, 07:30 AM
mirepoixmatt's Avatar
Default Transmission Fault Warning
hi gents. Wondering if I can seek your thoughts. LR3 with 217k. For last 20k when I move to put in drive after startup I’ll get a transmission fault warming. Car runs drives and shifts totally fine. The fault doesn’t come back unless I do a shut off and restart. For example, if engine is running and I throw in park and then back to drive, the fault does not reappear. Hmmmm.
Old 07-30-2018, 08:49 AM
abran's Avatar
Does the vehicle have a rear locking diff?
Old 08-14-2018, 06:21 PM
03discotrayer's Avatar
I have a simular issue in my 06 lr3 with locking diff, what can you tell me
Old 08-14-2018, 06:27 PM
abran's Avatar
if you read the ECU for the rear diff it will likely say the your rear diff is "not calibrated". If after attempting calibration is still give the fault, you need a new rear diff lock motor. And then a calibration after installation.
Old 08-14-2018, 06:53 PM
Awesome, i just got my gap tool yesterday, i saw their is a fault on the rear diff so ill look into it, thanks
Old 08-14-2018, 07:08 PM
Just checked with my Gap tool i recieved in the mail yesterday
Rear diff
P080A-00 (2F) clutch position not learnt
transfer case
p1808-00 (28) 4- wheel drive low indicator -circut failure
u3000-54 control modual - system programming failure
those are the ones i could see that might have to deal with the transmition light
Old 08-14-2018, 07:17 PM
houm_wa's Avatar
Default That's it!!
I was gonna say I remember the "learnt" **** when this happened to me. New locking motor....
Old 08-14-2018, 07:31 PM
Cool beans, did you get it from the dealer or different part distributor
Old 08-14-2018, 07:36 PM
houm_wa's Avatar
Default I bit the bullet...
...and went dealer.
Old 08-14-2018, 07:40 PM
Thanks for the info, i appreciate the help
Quick Reply: Transmission Fault Warning
