-   LR3 (https://landroverforums.com/forum/lr3-28/)
-   -   using oil extraction pump for oil change (https://landroverforums.com/forum/lr3-28/using-oil-extraction-pump-oil-change-67099/)
Zelatore Jun 11, 2016 12:05 AM
I've never actually checked the threads. Then again, I never really gave much though to the drain plug at all; I've uhad zero worries about stripping it. Steel bolts into aluminum aren't exactly anything new. Of course I do my own oil changes and don't take it to the quicky-lube monkeys either.
As for the oil extractors I have several and use them regularly - just not on my cars/trucks. In the boat world you have to either suck the oil out from the dipstick or have a drain system plumbed into the pan since you can't exactly get a catch can under the engine when it's sitting in the bottom of the bilge. I'm not a huge fan as they never get all of the oil and you just know the worst crud will be built up in the lowest point. It's also nice to have a magnetic drain plug you can inspect when you remove it.
houm_wa Jun 11, 2016 04:12 PM
Hate to be the bearer of bad news but the threads are aluminum and they WILL eventually strip. This happened to me and after ruling out a new pan as an option (the part is $1800) I designed a new plug and had a local fab shop help me with the machining. It's been installed a while now and works fine. Changed the oil for the first time with it a few months ago. Takes longer (smaller drain hole) but that's ok. I had a home tapped into an OE drain plug and fitted some stainless steel pipe fittings to it. I then permanently put the drain plug in. Their is a new cap at the end of the fitting that is used for draining.
