Wet floorboards. Fixes not working. Help!
2006 LR3 SE - I've had water soak both driver and passenger side floorboards over the past several years. I have recently replaced both sunroof drain hoses and replaced the lower windshield cowl. Just had a big rain and guess what, the floorboards were wet. Not soaked, but damp. What am I missing? Where else could water be getting in?
Thanks! John Kansas City |
1 Attachment(s)
There are typically three entry points:
Sunroof drains (front and rear) Cowl A-pillars Did you service the exterior a-pillar trim? |
No, I have not serviced the A pillar yet. I will look into it immediately. Thank you!
Originally Posted by jmac
(Post 687372)
Thanks! John Kansas City 30 second repair and no tools needed. just pull the old ones off, line the new ones up and hit em down with your palm |
$100?
Where are you sourcing A-Pillar trim pieces for $50 each??
Originally Posted by houm_wa
(Post 687443)
revised...only $165 total |
I work for a company called Lucky 8 in Clarence Ny i have these A Pillars in stock the pair would be $ 200 shipped if interested please email me at miker@lk8parts.com thank you
Have you blown out the AC drains on both sides?
Originally Posted by 06LR3HSE
(Post 690202)
(Post 690203)
I have not done that. I ended up changing the A pillars and no longer have water in the floorboards. But guess what, we had a gigantic rain last week and there was water in the dome light. That has never happened. So now I've got to figure that out...
They're on the L and R front corners of the sunroof tray. Passenger side exits behind the side grille. Pop off the grill and snip the end off the drain (clog point). Drivers side is a little trickier. Pop off the wheelwell shield and reach up towards the steering wheel in that cavity. Best bet is a razor blade to add slices. Also blow air from the top through the drains to clear it out |
