What does this do?
Apparently, it breaks.
Is the vehicle running poorly? That looks to be in the area of the MAF - could be reading O2% for fuel mixture? Sorry I can't be of more help right off the bat. Dont really know off the top of my head as I am relatively new to the LR3 - the service manual link in the Tech sticky might help...as well as the numerous gurus on this forum. |
Originally Posted by Dv8er
(Post 599181)
Its for the EGR system - according to the service manual that is called the Full Load Tube. Throwing any codes?
It's the pcv hose. You now have an engine lean issue from this. As you now have unmetered air entering. You also have dirty air entering the crankcase. You now need an oil change too.
Originally Posted by Coleroad
(Post 599227)
Its one of the hoses that goes from the valve cover to the intake, not the main PCV return hose. Don't be running the motor too much but in all honesty it's not the end of the world, you don't need an oil change, but you could do one if you really wanted to. Just replace the large intake tubing (or have the shop do it that broke it). I have run that motor with no intake beyond the throttle body and nobody died... |
Does anyone have a part number for this?
Still on the search for this part number.
You've been running it like this for almost a year???
Originally Posted by houm_wa
(Post 637549)
