2011 LR4 5.0 Head Gasket replacement documentation
Old 05-12-2020, 01:26 AM
AGLR's Avatar
Large parts order in today.
Attached Thumbnails 2011 LR4 5.0 Head Gasket replacement documentation-20200511_232300.jpg   2011 LR4 5.0 Head Gasket replacement documentation-20200511_232337.jpg
  #52
Old 05-12-2020, 10:50 PM
AGLR's Avatar
Engine Tech Machine in Santa Maria, California with a 24hr turn around time on resurfacing the heads!
Attached Thumbnails 2011 LR4 5.0 Head Gasket replacement documentation-20200512_204808.jpg
  #53
Old 05-13-2020, 05:04 AM
huggi's Avatar
24 hrs is impressive. How much did they take off? Are you going to use head shims? I'm still waiting on my machine shop
https://www.innomach.com/images/IMS-CATALOG.pdf
  #54
Old 05-14-2020, 12:16 AM
AGLR's Avatar
I was told that only about 0.008 was taken off. Not enough to need shims.
  #55
Old 05-14-2020, 06:45 AM
huggi's Avatar
What's the cutoff? I'm still waiting to hear from my machine shop regarding how warped my head's are
  #56
Old 05-17-2020, 03:08 AM
AGLR's Avatar
I'm not aware of a cutoff, but I'm not concerned about 0.008. Did you come across any specs for that?
Getting the heads back together this weekend. Looks like I'll have to get some new tappets to set the exhaust valve lash back to spec (.25mm +/- 0.02). I'm closer to 0.3 to 0.38. Not surprising after 120k miles though. At least the intake side is hydraulically adjusted.
Attached Thumbnails 2011 LR4 5.0 Head Gasket replacement documentation-20200517_010936.jpg
  #57
Old 05-21-2020, 10:14 PM
huggi's Avatar
Any idea where to find the left hand thread crank pulley bolt - that says 12.9 on the front. The only part number I can find LR011952 does not mention reverse thread. Also, do I need one of those spacers too?
Thanks
  #58
Old 05-22-2020, 11:48 PM
AGLR's Avatar
Thanks
That bolt is solid, I'm reusing mine.
  #59
Old 05-30-2020, 03:12 AM
AGLR's Avatar
Heads back on top.
Attached Thumbnails 2011 LR4 5.0 Head Gasket replacement documentation-20200530_010609_capture.jpg   2011 LR4 5.0 Head Gasket replacement documentation-20200530_010603_capture.jpg
  #60
Old 06-01-2020, 02:25 AM
AGLR's Avatar
All head bolts torqued through sequence
Attached Thumbnails 2011 LR4 5.0 Head Gasket replacement documentation-20200601_002403.jpg
Quick Reply: 2011 LR4 5.0 Head Gasket replacement documentation
