2011 LR4 - catastrophic engine failure
I just got my 2011 LR4 HSE(90k miles), in December and I love it. I was convinced she was invincible. All it took was a mountainous road, a hot Arizona summer day and a 4500lb camper trailer to kill my baby. Anyone know of a repair shop that would want to take a full engine swap/rebuild in the Tucson-Phoenix area? There isn’t a vehicle I’d rather have, but I’m not even sure if it’s worth it or the actual diagnosis at this point.
I was was driving along the interstate (watching my gauges intensely) when my temperature spiked to max. I received an low coolant warning an pulled off the road. I noticed coolant pooled on the ground but no noticeable leaks coming from the radiator. After about 30-40 minutes, the engine cooled and I started it with no more warnings. I tried limping it to the next exit (3 miles down the road). This was my big mistake, because I started to hear a clank/ticking noise and received a major engine check warning. Steam was pouring off the block and I immediately pulled over to the side of the road. Local mechanic tested the cylinders this morning- no compression.
Motor is likely completely toast unfortunately. You might have been ok after the first event. But continuing to drive afterwards on a engine that is extremely sensitive to overheating was probably your undoing.
Coolant crossover pipe is your likely culprit for the coolant loss.
what did you do?
calvink
06-26-2017 08:38 AM
