Alex Smith |
05-06-2019 11:54 AM |
2013 LR4 Engine Problems - Head Gasket???
It started with a coolant leak... I thought I found it, I changed a hose connecting to the water pump and thought I was good. A month after that, the low coolant warning came on. I topped it off and kept driving. A week later, it did it again. I topped it off, but in my hurried state, I forgot to put the coolant cap back on and drove it that day without the cap and amazingly, nothing spilled out, overflowed, or showed any warnings. The next day, I took it on a short drive and it spilled over and it said the engine was overheating. I pulled over and the engine temp went back to normal immediately and that is when I noticed that I left the cap off. I filled it with water and proceeded to drive home. Right before I got back, I lost all power when accelerating and the engine was making a ticking noise and then the temp shot up. I pulled over and there was a lot steam coming from the engine and I realized that the manifold was incredibly hot. It went straight to my mechanic and he did a leak down test and he said that the block seems ok, but there is massive pressure in the block for some reason. He thinks it is just the head gasket, but doesn't have the time to do the job so I am looking for someone else. Another mechanic wanted to sleeve the cylinders and quoted $5,000 for new head gaskets and the sleeve job. Can anyone advise me on this and possibly refer a mechanic in the LA area? I am in north LA County in Santa Clarita. Thank you all in advance.
