2016 V6 LR4 oil change??
Yes, you can indeed perform the oil change yourself. The most popular way to remove the oil (which is what I do) is to use a hand operated Mityvac to remove the oil. Additionally you will need a 35mm filter wrench to remove the top of the oil filter housing. The tube for the Mityvac attaches to a siphon in the oil fill line that travels down into the sump. Its sounds complicated, but its by far the easiest of my 3 vehicles to change the oil.
Wilybyrd
'10 LR4
Wilybyrd
'10 LR4
