3l v6
Old 12-01-2019, 05:06 PM
LR Techniker's Avatar
If you catch the chains in time, catastrophe can be avoided. If you let it jump too many teeth like I have seen, there will be piston contact and I have seen these camshafts snap as a result.
As far as that being the only thing, if you let it overheat and it blows a head gasket, that's usually a deal killer too, as the head bolt threads will likely give out.
Old 12-01-2019, 07:35 PM
Columbiar's Avatar
Wow. Sounds like the 5.0 is just a really bad engine.
Old 12-01-2019, 11:53 PM
ColoLR's Avatar
This discussion above is the SC V6
Old 12-02-2019, 05:42 PM
The 3.0 and the 5.0 are the same, minus two cylinders. Its great for us, because we only have to stock one set of chains, it fits them both. We just stock a different supercharger gasket and different r/s valve cover and l/s valve cover gasket to differentiate the two.
RoverSeriesInf
05-30-2024 07:20 PM
lordmorpheus
08-19-2019 03:54 PM
7smoothoperator7
10-19-2014 07:09 AM
Lawndart
01-07-2014 09:02 AM
aerokurt
12-05-2006 06:34 PM
Quick Reply: 3l v6
