Ground screw for fuse box 2011 LR4
Hi everyone, I bought a used 2011 LR4. I am trying to connect some internal led lighting to the fuse box, but I'm not able to find a grounding screw. Can anyone help me with a convenient grounding screw near the fuse box and how to get to it?
Originally Posted by boysha8
(Post 593202)
Originally Posted by BritishautoworksSD
(Post 593327)
The interior fuse is behind the glovebox. Quite a few ground connections are under the trim panels at the floor. First remove the trim under the glovebox and then to the right, removed this trim. Under you will find many connectors and 3 to 4 grounds to choose.
Can you help me with a picture or two? |
(Post 593327)
