Help - Airbag Light
1 Attachment(s)
Hi All,
Hope you can help. I'm rebuilding a Discovery 4, after it was salvaged. I'm in the final stages, but I'm stuck with an airbag light. The fault code in generic, B00D2-68 Permanent. I've checked each airbag, all look good. The readings on my diagnostic machine show's 0 ohms in location 12, does anyone know which this is? I found this diagram on another post (attached), does this relate to the location of the airbags/sensors? Any help would be appreciated. Rich |
12 appears to be an airbag built into the seat. If the seat was disconnected and the vehicle was powered up a code is stored that can not be cleared by reconnecting/power cycling. Its there until its cleared by a device/dealer. I only know because I had this issue when I pulled the seat to work on my amp. This week my software from RSW Solutions arrived and I was finally able to clear the code that I had for nearly a year. If you are getting 0 ohms, then its possible its still disconnected maybe?
