LR4 Buying Help
Hi,
Looking to purchase a used 2013 LR4 with about 69K miles. Here is the CARFAX. This will be my first Land Rover and to my untrained eye, it's a 1-owner and all of the maintenance was done at one LR dealer (where I would be buying it from) with pretty frequent work done, so things look good. Are there any red flags I might be missing? Would love to get the perspective of some experienced LR owners. Also, what kind of work should I be getting done after purchase in terms of preventative care? I chose a 2013 because I (hopefully) wouldn't have to deal with the timing chain tensioner issues, but I've read that the front and rear crossover pipes should be replaced. Can I wait a while before doing this, or is there a mileage I should really get it done by? (And if so, how much might I be looking to have the dealer/an indy shop do it)? Thanks in advance! |
Well done... only 65K and maintained by the very dealer you're buying from. The service manager should tell you what's next.
Prevention is different things to different people... and budget has a lot to do with it. If you are doing (preventatively) the cross over pipes, the supercharger has to come off. Might as well change its fluid too. Take a look at the owner's manual, maintenance schedule. It is all encompassing. You can see the details at topix: https://topix.jaguar.jlrext.com/topi...cle/lookupForm |
Other than brakes and tires there mostly likely you can just do oil changes up to 100,000 miles.
One preventive maintenance item I would suggest is replacing the air compressor drier. The drying beads begin to dissolve and create issues with the 3 valve blocks in the air suspension system. This is an inexpensive part, about $60, and can be done yourself or an independent shop. By replacing the drier now you may be able to keep away air suspension issues to come up down the road. When you reach highter miles toward 100,000 you will need to start looking at replacing transmission fluid and filter, differential fluids, brake fluid, coolant, water pump and thermostat. At that time the lower control arms may need to be replaced also. As for the crossover pipes, I would just keep an eye on them. |
Thanks for the tip on the drier.
(I ve done everything on your list except that). You missed transfer case and power steering. I’ll get on to that drier… |
Originally Posted by landy2023
(Post 867482)
Hi,
| All times are GMT -5. The time now is 06:11 AM. |
