LR4 Gearbox Fault P081C-64 Permenant...Help Please
Hi Guys, have no faults on dash until this P081C-64 Park input fault (Permenant) that only comes up once put into "D" then stays til ignition turned off then clear. Can drive the car and does't go to limp mode. On full scan I also have B110A-11 rear back door cent. lock which works fine and U0128-00 Lost comms with handbrake control module which also works fine???? Transmission/car drives normal however can't select sport/sequential and Gearbox fault on dash illuminates once "D" selected. Have checked fuses and wiring, continuity test shifter to mechatronics plug, played with linkage.... Has 140,000ks, did trans service 15k ago, Penrite full syn bmv for recommended zf's, filter, mechatronics seal, bridge seal valve body seals and pan conversion.
Any advice would be greatly appreciated thanks Greg
Nauticole (07-31-2023)
JeroPot
LR4
02-28-2022 03:52 AM
