-   LR4 (https://landroverforums.com/forum/lr4-38/)
-   -   LR4 interior lighting (https://landroverforums.com/forum/lr4-38/lr4-interior-lighting-60830/)
brandino Aug 1, 2013 10:12 AM
my interior led lighting in the door handles and around the gear shifter have all just gone out at once...i have tried fuse 57 and 21 and they are ok..any help would be great !!!! thanks
Savannah Buzz Aug 1, 2013 10:57 AM
warranty?
roverguy7 Aug 1, 2013 11:05 AM
What year?
By the lighting around the gear shifter, do you mean the illumination from it, or the light that shine down from above on that area?
Does the analog clock illuminate?
brandino Aug 1, 2013 11:48 AM
its a 2010 and yes all the lights from it and the light that shines down on it..and the lights behind the interior door handles and map pockets
brandino Aug 1, 2013 11:50 AM
its a 2010 and no warranty...yes its the lights from the inside the shifter column area and the lights that shine down on it ..and the lights in the door handles and map pockets
brandino Aug 1, 2013 12:09 PM
and clock does not illuminate either :(
roverguy7 Aug 1, 2013 12:14 PM
Back lighting of the shifter surround is on a completely different circuit then the ambient lighting in the doors, clock, and waterfall lighting from above.
What about the rest of the interior illumination, all the switches and such?
Make sure the dimmer dial by the light switch isn't turned all the way down.
brandino Aug 1, 2013 12:25 PM
anything that dims is out..i just checked...is there a dimmer switch fuse??? spedo lights...touchscreen and a few buttons will lite up...
roverguy7 Aug 1, 2013 12:34 PM
Do the high beams, and turn signals work?
If so, you're looking at either the lighting switch itself, the CJB, or the wiring in between.
No fuse for the dimmer.
brandino Aug 1, 2013 12:51 PM
oh boy..the cjb does not sound like its alot of fun $$$$
