New owner / New issues
New 2 day owner of 2015 LR4 HSE with 108314 miles. I'm just out of a year's long relationship with my 03 HUMMER H2 so I'm well aware of "older big heavy 4x4 vehicle' issues.
So, on the LR4 I had the ECO light on when purchased and button produced an error msg that it wasn't available. Read probable secondary battery issue so have one on order. HVAC blower has very light squealing when running on low speed but not when turned up on higher speeds, so have new blower & filter on order. Didn't have CHK ENG light but did have two pending codes - P2178 & P2180, so will be doing a MAF and TB cleaning as well as replacing air filter and adding a can of STP fuel system cleaner. Last night on way to restaurant ECO light disappeared (2nd battery regained a full charge perhaps?) but was soon replaced with CHK ENG light. After dinner it was really hard to restart vehicle and very rough idle. Ran ok on way home but light remained. Checked codes this AM and still have same 2 initial codes with addition of P2188 & P2190. Hoping the intended Air filter/MAF/TB & Fuel system cleanings will clear the issues. Have a couple questions tho - 1. where would the fuel filter be and is it a DIY at home change?; 2. I read on another post there is desiccant in the air ride pump system, so where is that located and can it be changed as a DIY in the garage? 3. Any links to pdf files for wiring, expanded body/drivetraing parts locations, etc? Will also be (or having done) a change of all fluids. And hoping that's about all for a while! 😁 Thanks for the add and TIA for any/all help. |
Originally Posted by Conch
(Post 923988)
So, on the LR4 I had the ECO light on when purchased and button produced an error msg that it wasn't available. Read probable secondary battery issue so have one on order. HVAC blower has very light squealing when running on low speed but not when turned up on higher speeds, so have new blower & filter on order. Didn't have CHK ENG light but did have two pending codes - P2178 & P2180, so will be doing a MAF and TB cleaning as well as replacing air filter and adding a can of STP fuel system cleaner. Last night on way to restaurant ECO light disappeared (2nd battery regained a full charge perhaps?) but was soon replaced with CHK ENG light. After dinner it was really hard to restart vehicle and very rough idle. Ran ok on way home but light remained. Checked codes this AM and still have same 2 initial codes with addition of P2188 & P2190. Hoping the intended Air filter/MAF/TB & Fuel system cleanings will clear the issues. Have a couple questions tho - 1. where would the fuel filter be and is it a DIY at home change?; 2. I read on another post there is desiccant in the air ride pump system, so where is that located and can it be changed as a DIY in the garage? 3. Any links to pdf files for wiring, expanded body/drivetraing parts locations, etc? Will also be (or having done) a change of all fluids. And hoping that's about all for a while! 😁 Thanks for the add and TIA for any/all help. 1. Fuel filters are IN the fuel tank. Its a job. 2. Correct, the desiccant container is a part of the fuel pump. 3. Send me a PM. Cheers! |
Thank you.
Well, pulled the Air filter covers and MAF sensors. Filters are apparently new (couldn't be cleaner. Was spraying the MAS with cleaner and noticed the o-ring on the right unit was on the side where the flex pipe to the TB goes. That puzzled me as I was sure I had seen it mentioned that it was supposed to be where it connects to the Air box. Decided to check the left unit and low and behold - NO O-ring to be found. No, it didn't drop & get lost. Just wasn't there. So, I have to get one of those before reassembly. Thinking it may have been messed up by whomever replaced the Air filters last. More learning....
Hoping I can find one locally. |
Mine doesn't have O-rings... can you pot up a pic? If the ECO battery's fully charged you'll have a green ECO illuminated in the cluster. These batteries do not last long, I went through 4 of them in warranty before giving up (besides start/stop's useless, annoying and very bad for the engine).
JLR vehicles are quite sensitive to battery voltage range, make certain the main battery's no less than 12.6 volts after sitting cold overnight. |
Originally Posted by jahummer
(Post 924082)
JLR vehicles are quite sensitive to battery voltage range, make certain the main battery's no less than 12.6 volts after sitting cold overnight. The secondary battery showed up today so I'll change that tomorrow. Sounds as tho they dont re-charge too well if they crap out that fast. At least I'll know if the batt turns the console light on and gets rid of the dash light or 8f there is another issue. I agree tho - first thing I turn off in my wife's CADDY that has that auto stop feature. And I'll keep an eye on the main batt. Well aware of "night drains" from living with it on my 07 Vette & 03 Hummer H2. Let them sit too long in the garage and you end up with all kinds of electrical gremlins! Neither was a daily driver so i kept them on a battery maintainer when not in use. Will consider same for the LR4 as it wont be a daily. Sorry for the looooong response. https://cimg1.ibsrv.net/gimg/landrov...b70d00529c.jpg |
JA -
Put the new battery in today. Hot green light in ECO switch (button) and the NO ECO yellow light on the dash is out. Ran some errands and no issues, but engine never stopped cold like my wifes Caddy does. Perhaps because we are in FL and with AC on maybe ECO doesn't engage. Going to have to find an owners manual and figure it out as I may have to set something else as well. |
Without resetting the BMS, it will take about 1 week for the metrics to re-adjust so the the system engages fully.
It is essential that the codes are clear and the batteries are fully charged. |
Originally Posted by guy
(Post 924285)
<deleted/> wrong thread
| All times are GMT -5. The time now is 09:38 AM. |
