Timing Chain Guide Rail Replacement Tips & Contest
My 2010 LR4 hit 160 miles and the timing chain guide rails had never been done. I guess I got lucky, but was waiting to do it along with some other work. After watching videos, reading the forums, and talking to a friend who is a great mechanic, I opted NOT to do a full timing chain replacement, only to do the guides.
HUGE shout out to ChronCrew in Youtube for making this video: I followed his steps and the process was smooth, but I want to make a couple of notes.
The problem with this method is getting the front camshaft plates back into place without buggering the RTV. This is the only part of the job that I would recommend a second set of hands. Stand by with a thin flat head screwdriver and a long-thin screwdriver.
https://cimg4.ibsrv.net/gimg/landrov...c96789c11.jpeg |
I am about 140,000 miles 229,000km. Thinking about doing the tensioners and guides on my 2010. I know it not accurate but some play on the chain through the oil filler cap after sitting a while. Once cranked tight as a guitar string. VVT values all good, no noise, no codes but something I want to do this summer as the tensioners seem to be bleeding down.
Do it! It's easier than it sounds. You just need the special tools mentioned above. The actual swapping of the tension guides takes 10 minutes. It just stakes 15+ hours to get to them. Mine is now running really smooth and quiet. I finally decided to do my tensioners because the I had a major oil leak on the passenger side crankshaft cover and a stuck thermostat. I did it all at once.
These are the tension guides I used: https://www.ebay.com/itm/362636168229 Send a picture of your guides when you get it out! |
One other note... I mentioned it's running smoothly, but it starts a bit rough. About 2 weeks later the LR threw a P0660 code - Intake Manifold Tuning Valve Control Circuit/Open Bank 1. Turns out I had forgot to reconnect this cable to the back of the air manifold. Thanks to this post for helping me identify the problem:
https://www.rangerovers.net/threads/...n-plug.369886/https://cimg4.ibsrv.net/gimg/landrov...ed803794e.jpeg https://cimg1.ibsrv.net/gimg/landrov...bb1d9e4f5.jpeg |
| All times are GMT -5. The time now is 06:40 AM. |
