Towing 28 lightweight camper with 2013 LR4
Is 4800lbs what it actually weighs when fully loaded (water, fuel, kit etc) or is that empty ?
The LR4 is rated to about 7700lbs tow weight so if you re really at 4800 you re well below the max weight. There is a debate about whether you should use a weight distributing hitch on the LR4 - I thought LR advised against it (something to do with the air suspension setup). But many people seem to use them successfully
LR4 is well powered and a pretty capable tow vehicle so if you re well within the weight parameters then you should be fine
4800 lbs is the dry weight. Im thinking I wont pack 2900 lbs into it, however having it weighed at a truck stop would be a good idea before a long trip with the fam. My only 2 trips with it thus far, just me, solo, with very little gear.
This debate about the weight distribution set up has me curious. I dont have a ton of towing experience but my Dad always took me on Camping trips, and always had WD. But he also, never towed with a Land Rover. How does the air suspension fit into the equation?
I did read in the manual that WD should not be used, but it didnt quite seem to explain why. So I went with my gut and got the weight distribution hitch with sway bar. Seemed to be the right thing, and it did tow ok that way. Maybe I should try towing without the WD to see how it feels? But, the idea of an accident due to sway, scares the heck out of me.
Under no circumstances should you use a weight distribution hitch with your LR4. We tow a 5000 pound trailer with my wifes 2012 and it took junking the weight distribution hitch to get everything to work properly. (Well that plus plugging in a 12 dollar harbor freight incandescent tow light set to activate the towing settings on her truck but thats another story)
Symptoms with the WDR were a significant amount of porpoising. With the normal hitch, the air compressor isnt working nonstop and its a very stable ride. I do miss the sway control provided by the WDR though.
So far we have about 15k towing miles in 2 years on our LR4. Handles it like a champ.
if you havent towed a significant amount of weight for distance with an LR4, id suggest refraining from dispensing conventional towing wisdom advice. A WDR works well with a traditional suspension setup but is pretty horrendous on the active suspension of the air sprung LR4.
Also, you mentioned something about a 12 dollar harbor freight incandescent tow light set to activate the towing settings on her truck. Does my LR4 have a tow setting? Still learning about my vehicle so,. I would like to hear that story.
Not discounting your advising against weight distribution hitches on the LR4, just trying to understand. Exactly how does it affect the air suspension system? What harm can it do, if all its doing is distributing weight? And what about the sway control bar? Can that be used without the Weight distribution set up? I worry about sway more than anything!
Heh guys,
why is a weight distribution hitch a bad idea on an air suspended Land Rover? - the hitch causes the air compressor to work continuously, something its not designed to do. It will eventually burn out from the abuse. Driving characteristics are that youll notice porpoising, the trailer nodding the rover up and down . Its particularly bad with a single axle travel trailer.
sway control. As long as tow mode is activated, the lr4 has software to detect and counter sway.
Activating tow mode - its a passive system that looks for resistance on the lighting circuit of either of the tow connectors. If you dont get a trailer icon on your dash when you hook up your trailer and turn on your indicator, towing mode is not activated. The harbor freight work around was worth it for us because tow mode alters suspension settings and shift points, plus disables the rear parking sensors when backing up.
bottom line, if youre towing with an lr4, years of conventional towing wisdom will get you into trouble unless your replace the airbags with coils.
I tow a 2009 Dutchmen Areolite 24RBLS. This is a 4,500 unladen and 6,000lb fully laden with out sway bars or weight distrubtion bars. Due to the passive system on the LR4 they are not needed. In fact by putting them on you can cause issues with the compressor trying to compensate for the WD bars. As for sway:
https://www.youtube.com/watch?v=cy4vfcX_BrU
to recap:
if your tow vehicle has coil or leafsprung suspension, use a weight distribution hitch with sway control.
if your tow vehicle is a Land Rover lr4 or RR Sport - just hook up the trailer and drive it. The vehicles systems will do the rest.
Ok. You all have convinced me to give it a try, towing my travel trailer without weight distribution. Maybe even without the sway bar. Do I need the Land Rover authorized hitch, or will my Curt hitch suffice? Also, A lot of videos mention special Towing Software that is called up when you plug in a trailer to the LR4. I dont remember seeing anything like that on the screen when I hooked up my trailer. Is there something Im missing or is it possible I need to get a dealer to install it?
TopGearMotorCompany
08-30-2005 06:13 AM
MarkB
01-03-2005 07:20 AM
