Trailer Hitch Key...
Old 09-28-2018, 10:15 PM
iconoclast's Avatar
Default Trailer Hitch Key...
Misplaced trailer hitch key. I have the key code off the lock... Do I contact parts department or service department?
Old 10-01-2018, 01:02 PM
Geo's Avatar
Geo
Geo is offline
Might be easier to buy the green **** with two new keys. It’s just a roll pin to knock out to replace it.
Lools like about $40 on eBay. Either that or a locksmith might be able to fashion new keys for you.
try part number KNW500010
Old 10-04-2018, 09:22 AM
iconoclast's Avatar
Do does one remove the green ****?
Mine does not have any pin or set screw holding it in place.
Old 10-05-2018, 06:02 PM
abran's Avatar
There is a roll pin.
Old 10-09-2018, 08:59 AM
iconoclast's Avatar
Mine did not have that or it was broken off. I wound up inventing a method of my own with a pry bar and the hitch was removed in less than thirty seconds. The handle still works as does the hitch but now I do not need a key.
Old 10-09-2018, 11:00 PM
Greggles's Avatar
There is a guy on Ebay that cuts keys based on the key #. He's in Australia by spot on with the key cut.
Old 10-09-2018, 11:15 PM
Geo's Avatar
Geo
Geo is offline
How do you have the key code and need a key if you dont have that green ****....confused how that’s possible...
Old 10-16-2018, 10:36 PM
Greggles's Avatar
If you clean the crud off your lock cylinder you'll see a #. That's the code, if I recall the numbers run from D1-57
gettingerb
10-10-2023 04:16 PM
Brendenv
02-22-2016 01:13 AM
sorbet35
07-21-2012 09:28 PM
bribake
02-17-2012 10:51 AM
fcs1965
08-25-2009 06:07 PM
Quick Reply: Trailer Hitch Key...
