Turning off seat belt chime and Light
I found this little gem. I was searching for how to turn off the annoying seat belt chime and voila....
1. Turn engine on and then off before seatbelt warning appears. 2. Fasten driver's seatbelt and then turn on engine again. 3. Within 60 seconds, disengage and re-engage driver's seatbelt 8 times. A chime will then ring confirming elimination of seatbelt warning. This eliminates both the audible and visual seatbelt warnings and warning light Got it right the first time easy enough. |
Time to resurrect this. Yes I have combed the internet for LR3 SEAT BELT Warning light. I want the chime as as SAFETY. Funny I find most people want to get rid of it. Lastly my Passenger side and Rear seat does not seam to indicate any warning that is it ON or OFF. There is no way of me knowing that.
So right now, ONLY Driver side senses Seat is OFF, Is this normal only DRIVER side? I also don't have a CHIME if I removed the SEAT BELT while the engine is ON. |
Bless you, bless you! Thanks for sharing your tip about disabling the annoying seat belt warning!!! It worked on my 2015 Range Rover!
