Want to install roof rails, afraid of breaking sunroofs?
New owner of a 2010 LR4 that did not come with a roof rack setup.
I have read a few threads on another forum about the glass getting broken while installing the rails? How common is this? Thanks, Mike Antioch, CA |
I want them too. Found at on-line dealer in Utah. Glass is broken because someone leans or drops something on it. As the bolts are not anywhere near glass. The rubber trim on top is where they will go and they do not come with instructions and are bolted thru the roof.
Originally Posted by Jagfixer
(Post 479072)
Thanks....I watched a couple of videos on youtube for the stock and aftermarket roof rails, I'd say operator error for that one thread I read about the dealer breaking 2 glass panels! After watching those videos I think I'll be ordering a some rails in the near future. |
Added short rails without worries
I just bought some short rails from craigslist :) and put them on my 2011 LR4 a few weeks ago. Oddly enough, the rails seem to fit perfectly without the thicker spacer under the rail. So why use the spacer? Without the thicker metal spacer between the rail and the roof mount, there is a chance that the rail itself will crack the glass roof. The spacers are there for a reason!!!
I suggest this particular youtube video, if you haven't seen it already: This video discusses the extended OEM roof rails but it is applicable for the short rails. Specifically at around 7 min 10 seconds the gent explains how the bolt, washer, spacer etc, go together but he doesn't really explain why the spacer is necessary. It's an easy job after seeing the video. I was concerned about cutting the channel but it worked out great. :cool: No worries about breaking glass! Any questions about install, just ask me! Johan |
I put the extended rails on by myself. Bought an oem set on eBay. Took about 1.5 hours to do it.
Don't cut the rails
With the newest OEM ones you do not need to cut the rear part off. So before you go sawing, try putting the rails on first after you take the plugs out.
Originally Posted by Stephen Tifft
(Post 645153)
When prying put the plastic rivets DO NOT leverage off the sunroof. |
Originally Posted by COSwede
(Post 480865)
I suggest this particular youtube video, if you haven't seen it already: How to fit extended roof rack rail to Land Rover Discovery 3 & 4 ( LR3/LR4 ) - YouTube This video discusses the extended OEM roof rails but it is applicable for the short rails. Specifically at around 7 min 10 seconds the gent explains how the bolt, washer, spacer etc, go together but he doesn't really explain why the spacer is necessary. It's an easy job after seeing the video. I was concerned about cutting the channel but it worked out great. :cool: No worries about breaking glass! Any questions about install, just ask me! Johan |
‘Unscrew’ the plugs, don’t pry them.
Originally Posted by Yohann Dias
(Post 761253)
Hi Johan - this is an old thread, but I was looking to understand why my LR4 roof rail installation cracked my panoramic roof glass. To be clear, the correct spacer installation prevents stress (and subsequent breakage) of the glass? Very grateful for you advice, since I will be replacing the glass, and don't want to repeat the same mistake! Thank you, Yohann
