ARB lockers installed in D1 diffs on my 69 Series IIA SWB 88
I don't have the time to do the install. Also my garage is filled with basement junk. Doing the basement floor this week so I can clear the garage. Maybe just call 1800IGOTJUNK.
Lockers with 4.14 years have arrived. Bust the budget but it is my Landy after all. GBR in Utah installed the gears ARB lockers and also installed thrust bolts in both front and back diffs. The front is a reverse cut gear set. A Toyota diff install in a Landy will not come close to these diffs in strength.
Ashcroft does a a similar mod but calls it diff pegging. The thrust bolt is brass and this prevents the crown wheel gear from flexing away from the pinion gear. The gears are 7 tooth pinion and 29 tooth ring gear. :-) :-) I will only get home on Friday next week so that is when the install begins
achapman
06-25-2013 03:40 PM
troybailey
06-25-2009 08:46 AM
