bumper building
We are gonna be building a front bumper and try to keep it simple and light so gonna build box gussets for frame and weld a winch mount across top
Thinking tube bumper, what size tube is common? Is welded tube OK or do I need dom tubing? If I do one of those pre runner hoops what is the angle? I also want to integrate a skid plate |
Beuler, beuler,,,,,beuler, beuler
I'll try to remember to measure my tube for you when I get home. ;)
Instead of making boxes in 1/4 plate to fit over the frame horns is there a box tube the right size to fit?
I would think either 6 or 8 inch tube would be about the right height. Is that what you are looking for? I'm not sure what the angle for the pre-runner bar would be. I like the idea of a skid plate underneath, though.
I figured the tube is 2" dia. Does the tube with weld seam and dom tube bent the same?
I think a stinger hoop is set a 30* rake...........
I have been kicking around a simalar idea... 2" double tube spaced just enough to place a receiver hitch in the center.......then use receiver mounted winch that can be moved front to back if needed. 30* stinger in 1.5" with with tubes running down and back toward steering with a skid plate on them...........supported from the outer edge of bumper to frame horns by 1.5" tubes. Welded black pipe should bend just fine........ I was thinkin schedule 10 pipe.. Idea based off of factory brush bar...........modified into proper bumper......... |
Looking to do a cross between a few others I have seen here are some samples I am pulling from
http://i543.photobucket.com/albums/g...psjyzjejnw.jpg http://i543.photobucket.com/albums/g...psw8oi3qbk.jpg http://i543.photobucket.com/albums/g...pst2bt848j.jpg |
1 Attachment(s)
Attachment 38438
Run the main bar out of 2x.25 wall DOM, use 3/8" for the winch plate and 3/16" for the rest. Make sure you have two bolts through the frame horizontally and one vertically to keep it from rocking. I loved my tube bumper but it just didn't measure up to the Rovertym as far as brut strength, practical protection, and recovery points. |
1 Attachment(s)
Virginia era early Rovertym
Attachment 38437 |
