CDL lever install on 2000 Discovery 2
I recently purchased a CDL lever from a Discovery 1 and today I tore into my Discovery II to install it. Everything went very smooth so I thought that I would share a few of my experiences here for others to look at when they tackle this job.
I'd say on a scale of 1-10, 10 being the most difficult mechanically, this job was a 3-4. you will need the following tools: 8mm 1/4" socket 10mm 1/4" socket 13mm 1/4" socket 1/4" ratchet 4" 1/4" extension Phillips screwdriver Flat head screw driver Drill 3/8" Drill bit to drill out rivets Cut off tool or Grinder Hammer Its helpful to get all the nuts and bolts with the new shifter, but if thats not the case ( like in my case ) I purchased a $24 Dorman Metric nut and bolt kit from autozone to save me running back and forth to the store for bolts. The process is simple, removing the center console is the most difficult process and the most time consuming. The next most difficult process is rebending the discovery 1 high/low lever to match the discovery II transfer case, be careful, gentle and take your time. There is a ton of room for adjustability there so being exact is not necessary. Here are some pictures to help: http://sphotos-b.xx.fbcdn.net/hphoto...16501217_n.jpg http://sphotos-b.xx.fbcdn.net/hphoto...61859101_n.jpg http://sphotos-b.xx.fbcdn.net/hphoto...31544174_n.jpg http://sphotos-a.xx.fbcdn.net/hphoto...82050998_n.jpg http://sphotos-a.xx.fbcdn.net/hphoto..._7764466_n.jpg http://sphotos-b.xx.fbcdn.net/hphoto...03668371_n.jpg http://sphotos-b.xx.fbcdn.net/hphoto...29141847_n.jpg |
Thanks for the parts list and pics! I'll be doing the same this week.
Question, did you have to heat the linkage to bend it? |
I think you should use heat to bend it, I however was lucky and got the job done without heat.:cool:
Originally Posted by IBUFFEM
(Post 389315)
Originally Posted by Richard.rover
(Post 447396)
How much bending did you have to do? How did you get the auto cable off and what did you use to put the cover on? Screws or rivets?
You don't have to bend, just install the hi lo housing I sold you. That way it's plug and play. Use some RTV when mounting the hi lo housing. The hi low linkage will match right up with the new housing. Abran |
1 Attachment(s)
Originally Posted by abran
(Post 447409)
Hi Richard,
Unfortunately I can't test till I get power to it.
[QUOTE=abran;447409]Hi Richard,
You don't have to bend, just install the hi lo housing I sold you. That way it's plug and play. Use some RTV when mounting the hi lo housing. The hi low linkage will match right up with the new housing. The shifter cover you sent me doesn't fit. It's has a bunch of holes and is too big. |
Shifter cover, or hi lo selector housing? I think you are talking about the sheet metal plate that holds the rubber boot.
I'm talking about the small rectangle aluminum piece with 6 screw holes and screws. It mounts onto your transfer case and has the lever which the hi lo linkage connects to. Did you look at the link I sent? |
SOrry, I answered from my phone.
So it looks like you got it all on there with no bending. |
| All times are GMT -5. The time now is 08:49 AM. |
