-   Modifications (https://landroverforums.com/forum/modifications-33/)
-   -   Discovery 1 Rear Lamp Guards (https://landroverforums.com/forum/modifications-33/discovery-1-rear-lamp-guards-41960/)
Rover_Hokie Jul 4, 2011 09:54 PM
In regard to securing them from people, you may try some less common "security screw heads" like torx, square drive, hex with center pin, or star drive. I am thinking about some for my D2, and will probably replace the factory screws as the D2's uses the factory screws that hold the lights on to hold the guards one.
Some examples here:
http://securityscrew.com/
wheelgarage Jul 18, 2011 03:29 PM
Originally Posted by honda50r (Post 255496)
I'm out of town and accessing online (I love the mobile version.) But I'll try when I arrive back in town.
bumpity.....:)
Travelor Jul 18, 2011 05:32 PM
Hey Hey -
So they actually made a set of rear guards for my Disco I? - I have the front brush guard - and on the rear I have holes with no guards - I guess the means the PO removed them or they got "ripped" -
In any case, can any one direct me to where I might find the replacements?
Thanks,
In Peace and Agape,
Trav...
honda50r Jul 18, 2011 09:48 PM
Stay on the forums. It seems these came factory on quite alot of Rovers. I'd say your best bet is people parting out their Rovers, that's how I found mine.
don't worry wheelgarage; I should have my baby back by Sunday.
wheelgarage Jul 19, 2011 09:41 AM
Originally Posted by Travelor (Post 258027)
Hey Hey -
Thanks,
In Peace and Agape,
Trav...
Ditto with mine.....have that whole that needs to be filled.
I bought a used set by one of the forum members, but wonder how the other side installs on the body.
honda50r Jul 19, 2011 01:25 PM
I'll be back in town Sunday, I'll help you out amigo
Rover_Hokie Jul 20, 2011 06:40 AM
Ebay, but they are not cheap for the D1 or D2 if you buy them new. Search "lamp guard" and "light guard", they are listed sometimes either way.
Joe511 Dec 27, 2013 04:15 PM
I was wondering to install these do I get sheet metal screws or are there hardware kit sold seperately ?
abran Dec 28, 2013 04:32 PM
The stock way to install them is to use a "rivnut". It is a rivet that acts as a nut. This is how they came from the factory. You can buy a rivnut tool for around $100. Or there is a write up on disco web forum about installing a rear ladder and the author uses rivnuts without the tool.
You could also remove the rear interior panels and use bolts and secure with nuts and lock washer from behind. The guy that shows his installed on here actually put 3 bolts, but factory had two rubber stoppers, one on tpo and one on bottom with a single Allen head bolt in the middle with a plastic spacer (same height as the rubber stoppers).
Joe511 Dec 28, 2013 05:53 PM
Thank you a lot
