KAM Ring and Pinion Press Release
Rover Dog is very proud to announce the Official Release of KAM gears in the USA. You may ask yourself, Why is this so important to the Land Rover community? Well, we have 8 game changing reasons that are sure to change your mind.
1) Reverse cut fronts! 2) The same price for standard and reverse cut gears! 3) (4.10) and (4.75) gears for you P-38 Lovers! 4) Not 1, not 2, but 3 choices of classic Rover gear ratios for you! (3.8) (4.10) (4.75) 5) Dyno static tested by Land Rover Engineers to be stronger then stock, (3.8) 70% (4.10) 25% (4.75) 50% 6) Each gear set is matched and lapped-in by a Gleeson lapping-in machine for optimum set up 7) All gear set are made from certified steels, dedicated drop forgings and carefully controlled heat treatments. 8) Best of all they are only $328 a set! We at Lucky 8 are striving to be your first choice for Land Rover drive train. Let us know what we can do to earn your business for more info http://lucky8llc.com/Search.asp?Manu=KAM |
| All times are GMT -5. The time now is 02:26 AM. |
