off-road problem
I have a 1990 Range Rover. I have the differential unit and viscous coupling limited slip system. I went mudding, got stuck (the system is automatic) and my permanantly 4-wheel drive (AWD) wasn't working. only some wheels were spininng. is my differential unit and viscous coupling LSD broken? If not, what went wrong?? PLEASE HELP.
RE: off-road problem
You don't have all wheel drive, at best with your system, you have 2, one front one rear at any given time.
I had to spend over $2500 to make my D2 crank all four wheels at once, out of 20 trucks I was with on a trail run today, only 3 of use could lock all four, some had 3 wheels, that being a locker in the rear and a open front diff, probably 14 only had 2 wheel drive. This is true with all 4wheelers and a misleading name to call them. Mike |
Sounds like your Rover didn't come with Electronic Traction Control....... Best bet is to get some ARB Air Lockers installed and run them when off road.
[quote]ORIGINAL: TexasBadlands
Sounds like your Rover didn't come with Electronic Traction Control....... Best bet is to get some ARB Air Lockers installed and run them when off road. ;) [/quote Have you installed ARB's on your 02? If so, how did you get around not having a CDL or are you just running with an open t/case? Mike |
