OME lift
Old 06-19-2007, 06:55 PM
N.Franklin's Avatar
Default RE: OME lift
Ill be ready to buy in a couple months, Id like to order about a week before I redeploy back home. I didnt know if the mediums were too soft or not, thanks for clearing that up for me.
  #22
Old 07-18-2007, 01:23 PM
bigugly82's Avatar
Can I use the link above to swap out stock susp. w/OME or ishould I use another set of instructions for that?
Thanks
  #23
Old 07-27-2007, 08:26 AM
Franklin stay away from the standard OME shocks and only use the H.D. shocks they offer.
Same with the springs use the 751 front springs and 762 rear springs, you'll love the way it handles.
Mike
  #24
Old 09-30-2007, 01:19 AM
69mgb's Avatar
6th Gear
Where would be a good reputable place to buy the OME kit from? I would be interested in buying ine before the winter. Thanks!
  #25
Old 09-30-2007, 07:37 AM
Contact Tony at Cerrone's in San Francisco, his prices are as good as they get on line thru his forum.
His number is 650-365-4145, his stock is good and he usually ships same day.
  #26
Old 12-12-2007, 12:16 PM
johnnybob06's Avatar
Hey!
So, what would it take to get a good OME lift, but keep the SLS?
I love the height and look of a few good inches lift, but I love having the SLS.
One question, if I were to get the lift and keep the SLS, would the rear end of the truck raise like it did without the lift?
Let me know!!
Thanks!!
oh and btw, I MIGHT, like later down the road add a front grill guard, if that at all, so I really don't want a heavy stiff ride. All I'm looking for is a smooth ride, but lifted.
Thanks!
John-Robert
  #27
Old 12-12-2007, 05:10 PM
OME 779 front springs, stabilizer and HD shocks and an 2" RTE spacer block for the rear suspension and you will be set.
  #28
Old 12-26-2007, 10:30 AM
bamarover's Avatar
How come the lifts never look like they do anything? I want a big lift where people can tell its lifted. Should i do a body lift too?
I mean come on, i live in Alabama.....i need a big truck.
  #29
Old 12-26-2007, 05:53 PM
okdiscoguy's Avatar
The suspension really won't allow too much. You can get 3" before needing to change brake lines and changing pinion angles. I think ajh is trying to go higher. Might PM and see what he has run into for downfalls.
  #30
Old 12-26-2007, 08:11 PM
You must not be looking at the right lifts, a good near 3" lift stands out in a crowd, along with some good tires.
Quick Reply: OME lift
