OME lift
Old 12-27-2007, 08:32 AM
bamarover's Avatar
Default RE: OME lift
i must not be looking at the right ones. But to get that look you have to upgrade alot of things right? i just want a lift where i don't have to change driveshafts, brake lines and etc, and still look like its been lifted.
  #32
Old 12-27-2007, 10:09 AM
If you use the OME lift, you'll have a good lift, the looks, a much better ride and won't need any extra mods.
Call me and I'll go thru the different OME lifts to see what works best for you.
303-862-7680
Colorado between 7am and 8pm
  #33
Old 01-18-2008, 02:11 AM
johnnybob06's Avatar
ORIGINAL: Disco Mike
OME 779 front springs, stabilizer and HD shocks and an 2" RTE spacer block for the rear suspension and you will be set.
Sounds great! but what about for the rear?.. I'm only asking because you only mentioned the 779 front springs.
Is there a website that I can go to just to see exactly what I'm buying?
Thanks again!!
John-Robert
  #34
Old 01-18-2008, 07:22 AM
JR,
You have my number, call me.
  #35
Old 02-16-2008, 06:05 PM
raid13's Avatar
mike, are you running 751 springs in the front and 762 springs in the rear?
i have seen the pictures of your discovery and i think that the hight i want
i plan on installing heavy front and rear bumpers.
  #36
Old 02-16-2008, 07:06 PM
That is the package you want, along with their HD shocks and a stabilizer.
  #37
Old 07-29-2008, 11:45 AM
Disco1insocal's Avatar
5th Gear
Hi Mike
Thanks again the the help with the codes. What sites do you recommend for OME parts? Also what size tires do you recommend on the stock 96 disco 1 wheels?
  #38
Old 07-29-2008, 12:23 PM
Call Tony at Cerrone's, 650-365-4145, he has about the best prices on line for OME.
As for tire size, 245/75/16's work well.
  #39
Old 08-04-2008, 12:01 PM
5th Gear
Can I get away with a 265/75/16 stock ride height or is 245/75/16 the max tire. If i can do the 265 will i need to modify anything(i.e. cut fenders, wheel spacers). Also if I do the lift I should go with the H.D springs front and rear. Do i need to do the shocks as well or can i piece it together little by little.
  #40
Old 08-04-2008, 05:02 PM
265's will rub on a unlifted D1.
Quick Reply: OME lift
